HTML to PDF
Dear Expects,
            I am using the HTML To PDF Converter is CutePDF Writter. When ever i am create the PDF by using Print Report.vi the dialog box will open.
How can i with out dialog box create the PDF.
Please tell me the Configuration to make without dialog box.
        Thank you
          M.S.Sivaraj
(5,061 Views)
You converter should have a configuration option to make a kind of a "silent print".
I'm using PDF Creater which you can configure to create the file in the background without popup.
Christian
(5,058 Views)
Or use FreePDF XP: http://freepdfxp.de/
Here you can turn off print dialog:
Andrey.
Message Edited by Andrey Dmitriev on 03-17-2009 01:49 PM
(5,019 Views)
