function returning pointer to a table
I have a dll witch returns pointer to table of integers:
_declspec (dllexport) int process( char xname[], char yname[], char zname[], int DummyType,
                                  char OcciCondOff, int size)
 int *tab=new int[size];
return *tab;
is it possible to receive this table in LabView using Call Library Function Node? How? any other way to get the table from a function linked in dll?
Thx!
(3,543 Views)
Hi przemmo,
My understanding that your problem is the thing that the returned value is a pointer.
I suggest you have a look at this link:
http://zone.ni.com/devzone/cda/epd/p/id/4489
Marton
(3,500 Views)
Copy the data with any mem copy routine. You can use LabVIEW's mem copy
functions (defined in \cintools\extxcode.h). Or windows memcopy routines,
for example the routines to copy strings.
In the copy routines, use the pointer as source, and an array of U8's as
destination. This array should be properly initialized (it should be big
enough). The copy routine will copy the data to the array.
Now you have an array of u8's that has your flattened data. You can use
normal LabVIEW functions to convert it to the type you need. Typically, you
use resize array, interleave and decimate array, swap bytes and words, and
functions like that.
Wiebe.
(3,495 Views)
