HTTP and LabVIEW
When it worked before, was that without the authorisation? If so, the malformed header was probably ignored by the server. After you added the authorisation, it would stop working until you sent a valid authorisation header.
(blog)
Message 11 of 16
(3,502 Views)
Yes, it was with authorization.
Message 12 of 16
(3,492 Views)
would you be able to share the working .vi?
I am having similar trouble but not able to fix it. Your solution would help greatly
Message 13 of 16
(2,886 Views)
This was Sam's solution:
Your 'headers' you are sending are malformed.
The 'add header' VI adds a key/value pair to the HTTP header. You are building the key value pairs yourself instead of letting the VI do them for you. You should call the 'add header' VI for each key/value header pair you want to send.
To do the authorisation, you just need to put 'Authorization' into the 'header' control and then your 'Basic **password**' as the value. That will add a line "Authorization: Basic **password" to the headers. The HTTP Client VI handles the other headers automatically itself (e.g. the timestamp).
You should check what is actually being received by the server (e.g. by checking server logs / logging the request / using a 3rd party checking service etc.).
Message 14 of 16
(2,866 Views)
Thank you for your response.
I have tried to follow your advice but not about to get it working. Still getting authentication issues. Please find the attached .vi
I have used Postman (API monitoring tool) to check what is received and works fine.
Message 15 of 16
(2,841 Views)
This helped.
Over the years solution is persistent!🙂
Message 16 of 16
(2,629 Views)
