Half duplex in LabView?
Hello everyone!
Does anyone no how to communicate with a radio
modem using LabView? The problem is that I have
to communicate using half duplex serial
communication but all the standard VI:s in
LabView are using full duplex. When using full
duplex I can send data to the modem but I can not
recive anything. To recive data I must set the
RTS (Request To Send) line to low but I dont now
how to do that.
I cant be the only one in the world that have
this problem in LabView so please help me!
Regards
/Andreas
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,342 Views)
burtrask@my-deja.com wrote:
> Hello everyone!
> how to do that.
> Regards
> /Andreas
Andreas,
To set the RTS line, use the following VI (which isn't in the
pallette) -
VI.lib\INSTR\_sersup.llb\serial line ctrl.vi
The same thing is possible using VISA serial via the property node.
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting original.code@technologist.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
(5,342 Views)
I have a similar problem, communicating with an ABB Drive though Modbus Serial (half Duplex). The wiring is correct, but I am unable of receive data.
I do not have errors, I just receive a number that does not make sense, and if I ask the value of the next register is that value +128 and so on and so for.
I am using Modbus library, anyone know what is the best solution to this problem?
I write without problem btw
Thanks!
Adrian
(4,347 Views)
