Saving png photos with different names..
Hello guys,
I am not not so familiar with Labview so i would like some help. I have a Vi which is actually controlling 32 RBG lights.We use DMX protocol..everytime one led is on then we take a picture and then the led goes off..Then the second goes on end so on..we have 8leds in 4corners..So we have corner1_led1,corner1_led2 untill corner4_led8 .So in the end we have 32 png photos saved.What i want is to save the photos with different names and the numbers to start from 1 instead of 0.. For example if we select white light and  save the images as "new" the images are going to be named "new_white_0_0" instead of "new_white_1_1" . Do you have any idea how i can change it?
Attached current photos names and Vi.
Any comment would be helpful.
Thank you.
(2,983 Views)
Accepted by topic author MAGI2
The indexing terminal (the [ i ] in the for loop) starts at 0. When creating your filename, use the "increment" primitive from the numeric palette. Then your file names will start at 1 instead of 0.
I noticed from your VI that you do a lot of string concatenation to build the file name/path, you can use the format into string and build path VIs to make the block diagram look a little simpler. You could also update the deprecated functions (e.g. the open file) with the modern equivalents.
(blog)
(2,977 Views)
Sam_Sharp, i made the changes and the numeration starts correctly.Thank you very much for your help.I will also try the rest of your suggestions.
Have a nice day!
Thnx again!
Smiley Happy
(2,963 Views)
