Hand tool and zoom resume
I apologize for this easy looking question,  but neither the documentation nor my own tests seem to point me to a clear answer.
I have a waveform graph and I am using the zoom and hand tool on the graph palette.
1. After applying the hand tool, how can I resume to the original graph?
2. I zoom a part of the graph more than one time consecutively, let's say twice. After the secodn zoom, I would like to resume to the result of the first zoom.
The same way in which generally the zoom-in and zoom-out functionalities work.
On the graph palette, the left bottom icon of the zoom functions, offer just the possibility to resume to the initial version of the graph.
I couldn't find a way to achieve an incremental zoom-out as described above?
Is there any?
Thank you!
MG.
(2,644 Views)
Accepted by topic author MG70
1) Use the Zoom to Fit
2) You will need to programatically make this.  When you zoom in, store the X and Y scale data (max and min).  You can then make a button to go back to the previous zoom by then setting the scale data with the values you stored.
(2,628 Views)
Thanks crossrulz!
MG
(2,601 Views)
