windows shutdown, proces kill detect
I am working on aplication that needs to preform some actions before windows will close.
There is a way to detect if someone closes system or logs in/out?
And is there a way to prevent from killing my aplication from task manager or cmd? It would be nice if program could preform last actions before is killed.
Thanks in advice 🙂
(3,529 Views)
Thanks in advice 🙂
A seven-second Google returned this gem:
http://digital.ni.com/public.nsf/allkb/66659ACE17C686418625736000606A64
Bill
CLD
(Mid-Level minion.)
(3,526 Views)
While you're at it, you might also want to consider handling the Panel Close? event. It fires when the user closes the VI's window. Similar reasoning, same solution. Discard the event, and then do whatever you need to do to return your system to a safe state and stop the application.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,493 Views)
