Handling a state machine using a single button
It's your second example I'm referring to...
Message 21 of 23
(974 Views)
Ok I just downloaded the program to make sure it is doing what I told you it was doing. I added the states program 1, program 2, program 3, program 4 to the array and hit start. It went to program 1 then back to none then back to program 1 until I hit next. then it does program 2 back to none then back to program 2 until you hit next or stop.
Did you turn on the light to see the execution? I am not sure why it would work differently for you.
Tim
GHSP
Message 22 of 23
(963 Views)
Ah yes, now it works. I was fiddling with the wrong array 🙈
Thank you and I apologize for the inconvenience!
Message 23 of 23
(943 Views)
