Handling bits of data
Hello Everyone,
I want to bit wise manipulation of data.
I have 6 bit of data ranging from 0 to 63 and 2 bits of data ranging from 0 to 4.
I want to add so as to get one byte of data.
Meaning 00000111, should give an output of 7  (first 6 bits from first data and 11 from second data)
I have two arrays of these values.
Please help or provide any information if avaliable for manipulating bit wise opeartion..
Thanks a lot in advance.
Avni
(3,414 Views)
Hi Avni,
Please see the attached vi for handling the data bitwise.
Hope this will be helpful to u n is as per your need.
Alifiya
(3,406 Views)
Thanks for your reply.
I am using LabVIEW 8.2 .
Can you please give the VI in version 8.2.
Once again thanks a lot.
Avni Vyas
(3,400 Views)
Hi Avni,
Plz find the attached vi in L8.2
Alifiya
(3,397 Views)
Tip: The for-loop is not required. The Not Equal To 0? function is polymorphic. Smiley Wink
(3,381 Views)
