TCP network connection information
Hi to all
Im using the Data Logging and Monitoring Example for Distributed Systems and i want to do some modifications.
In the attached image,  i add  to the Server console VI an array indicator to see the connection of the clients to the server, when i  open the  client  console in other PC on my network it appear in the array.
I want to extract some information of the connections, like the Computer name, IP address and Port used, but i didn't find nothing in internet. Can someone give me a clue, please? thanks
(3,361 Views)
That array is just an array of TCP refnums. The information you're looking for won't be in there, which is why you can't find it.
(3,351 Views)
No manner to work with TCP refnum to extract information?
i saw something similar but it list a lot of connection.
(3,344 Views)
That VI is something completely different. Whoever wrote this was getting some connection information from the Winsock driver. I haven't a clue how this maps to the LabVIEW refnums (if it does at all). You will need to ask whoever wrote that code.
(3,305 Views)
