Hard to explain problem
I have a problem i can't put into words (maybe there is already a topic, but i can't find it) so, see the attached image.
Message 1 of 22
(5,207 Views)
Adding an image is good but that either explains the problem. Please explain with that image what is the problem you are facing.
Message 2 of 22
(5,192 Views)
Image looks good Smiley Wink
so what are we all suppose to do with it?
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 3 of 22
(5,191 Views)
I want to move (in this case) the first 3 elements behind the last elements, the index becomes bigger, that is important, because I want to take an average form the index with an 1 as element.
Message 4 of 22
(5,180 Views)
Check out the Rotate Array function.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 22
(5,174 Views)
Hi henk,
- get a subset array from your first 3 elements
- append it to your existing array with BuildArray
- replace the first 3 elements by zeros
That is what you should do based on your image and explanation…
@Yamaeda: RotateArray doesn't increase array size. You might rotate and prepend 3 addtitional zeros in front…
Message 6 of 22
(5,162 Views)
Tanks a lot! I will give it a try
Message 7 of 22
(5,152 Views)
Do I have to use the concatenate function in builarray?,
Message 8 of 22
(5,142 Views)
Yes. Otherwise you add a new dimension to your array…
Message 9 of 22
(5,140 Views)
and how do you replace 40 ones into zeros?
Message 10 of 22
(5,133 Views)
