Hard to explain problem
Multiply them with 0. Smiley Wink
Message 11 of 22
(2,836 Views)
But how can you do that with 40 elements at once?
Message 12 of 22
(2,834 Views)
If the indices are fixed then use replace array subset.
you can use for loop and case structure to build some logic if the indices are not fixed.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 13 of 22
(2,833 Views)
Hi Henk,
your questions show your lack of basic knowledge of LabVIEW so I advise you to take all those FREE online courses offered by NI!
The key word is: polymorphism! Read the LabVIEW help on this topic…
Message 14 of 22
(2,829 Views)
you have in replace array subset one input index, how can I put the first 40 in the input?
Message 15 of 22
(2,828 Views)
O I will read that, ignore previous reply
Message 16 of 22
(2,830 Views)
Hi henk,
you give the first index to replace and an array with new elements. No need to replace 40 (consecutive) elements on their own…
Message 17 of 22
(2,827 Views)
So I put an zero in index input, and how can I build an other array with 40 zeros? or isn't that what you mean?
Message 18 of 22
(2,815 Views)
Accepted by topic author henk_kempen
Hi Henk,
please go through LabVIEW Basics courses…
There's a function named InitArray. Guess what it's for…
Message 19 of 22
(2,802 Views)
I will do that, thanks for your time, it really helped me on my way!
Message 20 of 22
(2,800 Views)
