Hardware Compatibility?
i wanted to ask if there is a hardware compatibility list for the NI Drivers.
We need to upgrade a system which is using PXI-4070 (DMM), PXI-4130 (SMU), PXI-6615 (Digitizer).
Unfortunately i did not find a list of compatible driver versions for the hardware.
Are all of these three devices compatible with the latest drivers?
(2,733 Views)
Accepted by Seau1
(2,708 Views)
Thank you, it shows the earliest version.
So the shown version or later is compatible with the device?
(2,692 Views)
Yes, otherwise it shows a range, like 15.0 - 2023Q3
Rolf Kalbermatter  My Blog
(2,688 Views)
That is good to know. Thank you!
(2,679 Views)
