Hardware Drivers for LabVIEW Community Edition
This topic was written on May 4, 2020.
Do you have a communication problem with your NI hardware on LabVIEW Community Edition?
Or are you looking for a hardware driver such as DAQmx, NI-RIO, myRIO which have a compatibility with LabVIEW Community Edition....?
At this moment (May 4, 2020), there is NO official driver which supports LabVIEW Community Edition.
If you would like to use your hardware with LabVIEW Community Edition, please wait the new driver released.
You can find the latest driver as following steps.
  1. Visit NI Driver Downloads - National Instruments
  2. Search and find a driver
  3. Read "readme". There is a compatibility information.
Certified LabVIEW Developer
GCentral
Message 1 of 16
(10,228 Views)
Based on recent history, the drivers will be released with a 20.0 version number.  And do expect them to not be compatible with LabVIEW 2016.  NI pushed to get the Community Edition out early to help during the whole COVID-19 mess.  I assume the commercial versions of LabVIEW and drivers are still due to be released when NI Week was supposed to happen (May 18th).  At least I haven't heard anything to the contrary.
Message 2 of 16
(10,202 Views)
Is your purpose to use NI hardware with LabVIEW Community Edition really for NON-COMMERICIAL USE?
Even for just a bit, using LabVIEW Community Edition for your job or research is not allowed.
LabVIEW Community Edition Usage Details - National Instruments
GCentral
Message 3 of 16
(10,025 Views)
Hi Emboar,
there might be people using older USB6008/9 devices for some kind of home automation, needing DAQmx.
Even the more recent USB6000-3 are available for a reasonable price tag, all requiring DAQmx!
(I have an old iUSBDAQ floating around on my (private home) desk, here the problem is to get drivers at all…)
Message 4 of 16
(10,017 Views)
Thanks GerdW,
Yes, I wondered there were such cases but just in case, I posted my concern.
(Actually, I have one old NI hardware too : D )
GCentral
Message 5 of 16
(10,010 Views)
Accepted by Tepig
NI-DAQmx Download - National Instruments
https://www.ni.com/en-us/support/downloads/drivers/download.ni-daqmx.html#346240
NI-DAQmx 20.0 Readme - National Instruments http://www.ni.com/pdf/manuals/374768af.html
GCentral
Message 6 of 16
(9,925 Views)
And I am also seeing LabVIEW 2020 Professional available for download.  But I cannot say if the NI license servers have been updated.  It will probably be another month before my corporate license server gets updated.
Message 7 of 16
(9,910 Views)
I could activate some software with my serial number!
GCentral
Message 8 of 16
(9,876 Views)
LabVIEW 2020 CE - with DAQmx 20.0 installed. There is no "Open VISA Test Panel" option in MAX
when selecting a serial device.
On the right hand side (of MAX), under "Communicate with my device" it says to right-click for this option.
The only option available is Rename.
NI-VISA 20.0 shows up under the Software list.
Tried installing NI-Serial 20.0 - no change.
Is this feature not available in the Community Edition?
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 9 of 16
(9,788 Views)
Hi, I tried using the DAQmx- 20.0 as well as 20.1 for my LabVIEW community edition. In both it gets struck in the below location and not completing the instillation.
Can you please help me out.
Message 10 of 16
(8,666 Views)
