Harmonic cursor XControl issue
Hi all,
I am using the Harmonic XControl found in the link below. It does not seem to work with LabVIEW 2011 or later versions. Can anyone help me fix this issue.
http://www.ni.com/example/31404/en/
Thanks in advance.
KM
Message 1 of 8
(5,948 Views)
What doesn't work? Is the XControl fixible or is its code locked?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(5,915 Views)
Thanks for your reply, PFA the error codes.
KM
Message 3 of 8
(5,902 Views)
...and why is the Facade vi broken?
Mike...
LabVIEW Champion
Message 4 of 8
(5,891 Views)
The facade vi has many broken sub vis, i am not able to figure out the issue.
KM
Message 5 of 8
(5,885 Views)
Hello Mike,
PFA the error code for all the broken SubVIs. The error seems to be common for all the broken SubVIs. I couldn't find any threads on how to fix this issue. Is there a work around for this. I so badly want to use this XControl for my application.
KM
Message 6 of 8
(5,872 Views)
Well first you have to find a vi that is actually broken, not one that is simply calling one that is broken. Look for a vi in the error list that has a red x to it. Those are the VIs that have the problem.
Mike...
LabVIEW Champion
Message 7 of 8
(5,843 Views)
I have the same problem with LV2014.
It seems to be a problem with LabView error:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/errors/run-time-type-not-propagated.html
Is there a version corrected for LV2014 ?
Thank you.
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 8 of 8
(5,692 Views)
