How to set the text size with Report Generator
Hi.
I am trying to set the size of some text with the report generator, but I am finding I can not do this. Here is a sample of the code I am using. Can anyone tell me what I am doing wrong please?
Many thanks, Alec
(4,043 Views)
Refer an example in example finder
<LabVIEW 2015 Path>\examples\Report Generation\Word Reports\Word Report - Conditionally Formatted Table.vi
(4,036 Views)
Missing info: What kind of report are you generating?
Ben64
(4,023 Views)
Accepted by topic author alecjcook
I was generating from a word template.
I hacked my version of the toolkit to give myself maunal control of the "from template?" flag. This had got its self permenatly stuck on "T". I have exposed this flag to the outside of the API so i can conditionally control weather I am using the template font or not.
Does anyone know how this toolkit should be used, or have I done the right thing?
Cheers, Alec
(4,020 Views)
From what you showed in your original post the font should be changed to size 20 bold. If not, the source of the problem is probably in the vi you modified.
Ben64
(4,001 Views)
The problem was a problem BEFORE I modified anything.
I was using a template (.doxt) and THEN trying to control the font later. I beleive you can not use BOTH of these features without modifying the toolkit.
(3,998 Views)
