Has anyone ever used the .NET TripleDES service successfully in G
I have a program where I need to do a TripleDES encrytion on a message, and .NET has a construct supported since v2.0.0.0 (mscorlib.dll), but I have been unable to get it configured and working. Looking for some assistance, so I don't have to create the DES encrytion algorithm dicretely.
Thanks.
(3,482 Views)
Could you please any errors or roadblocks you're running into?  These might help us get a better idea of exactly what's going on.
(3,445 Views)
There are actually a number of issues I am having, if you go into .NET constructor node for the TripleDESCryptoService Provider (mscorlib.dll v2.0.0.0.0) and invoke the CreateEncryptor method, it asks for an initialization vector (IV) which i have no idea of what exactly it is looking for. MSDN is fairly worthless for this, so i was just hoping someone might have an example available.
(3,421 Views)
Here is an example in VB.NET
http://msdn.microsoft.com/en-us/library/system.security.cryptography.tripledescryptoserviceprovider%...
It looks like if you don't provide the initialization vector, it generates one for you.
(3,412 Views)
Exactly my point, this method throws an exception error if the IV input is either wired with an empty array, or if left unwired it throw an error stating all inputs need wiring??
(3,406 Views)
The example is creating a new TripleDESCytpoServiceProvider object.  That is how you should model your LabVIEW code.
(3,401 Views)
Thanks, I'll see what I can do with this.
(3,395 Views)
