04-13-2014 08:26 AM
I want to know how to use the low level golden template and how to create a pattern for it with low level elements. I created a pattern using the golden template of the vision assistant, but tht doesn't work for the low level element.
I'm using this pattern in a match pattern, and I get:
Error -1074395247 occurred at IMAQ Match Pattern 2
IMAQ Vision: Invalid template descriptor.
Can someone please help me out?
Thanks in advance!
04-14-2014 11:19 AM
Hello Fernan1988
If you built a pattern matching script in Vision Assistant (IMAQ Vision Builder) and then made a Labview VI out of it using the "Create LabVIEW VI" option, the script works fine, but when you run the VI it gives me Error -1074395247. Well, you should take into account: this error is reported when IMAQ Read Image and Vision Info cannot read the template information properly. Typically this error will arise when there are different versions of Vision Assistant and IMAQ Vision installed.
also, have you reviewed this article?
Regards
Frank R.
