Has anyone managed to install LabVIEW 2020?
I got the download and it upgraded NI Package manager but NI Package manager can't find LabVIEW 2020
Tried several times with the same results... I guess we have to wait for the hard copy to arrive?
=== Engineer Ambiguously ===
(3,888 Views)
I have installed LabView 2020 x64 using the offline installer.
via the download link
https://www.ni.com/de-de/support/downloads/software-products/download.labview.html
if you do the 32 Bit Version, be careful not to download the Chinese language version (default), as I did once upon a time...
(3,874 Views)
That's the same file I downloaded and that is NOT the offline installer (file size 5 MEGA-bytes)
It just upgrades the Ni Package manager and tells it to download and install LabVIEW 2020
(3,849 Views)
I found the off line installers.
The link is in very small print at the bottom of the download page.
(3,841 Views)
I tried to link to the .iso file, but it is the same link as the landing page.
sorry.
I downloaded and installed
"ni-labview-2020_20.0.0.49152-0+f0_offline.iso" ~ 42,3 GB
english only
the 32 Bit Version is smaller in size 33,5 GB
it took me several hours to download from the NI Server ....
therefore I was very amused to see, I had downloaded and install the Chinese Version -
which results in some very nasty encoding errors on my European PC
(3,809 Views)
So far, after (finally) being able to load/install LabVIEW 2019 (took me only about 4-5 months, lots of struggles) reasonably successfully, I tackled LabVIEW 2020.  I managed to install LabVIEW 2020 Community Edition (32-bit), but on my Work Machine, I just tried loading LabVIEW 2020 (32-bit) "Regular Edition".  No problem loading just LabVIEW (no modules, no drivers).  Started loading anything else (one Module, the standard Drivers, only one-at-a-time), get the stupid "Please check your internet" or other misleading/inappropriate Error messages.
And I thought I had this knocked!  Pass the Humble Pie ...
(3,726 Views)
Partial success.  Did an "Uninstall NI Software and NIPM" pass, downloaded the 35 Gb .iso for LabVIEW 2020 32-bit, and gave it a shot.  Worked fine (so far) -- I have LabVIEW, DAQmx, VISA, PXI Platform Services, LabVIEW Real-Time Module, and FPGA.
One change I made to my usual "order" of installation -- as always, I installed (only) LabVIEW first, but this time, as it always "by default" turns on DAQmx, VISA, NI 488.2 (which I always manually turn off), and PXI, I let it install DAQmx, VISA, and PXI in the first pass.  Incidentally, I know NI got started making GPIB hardware many (>30?) years ago, and developed LabVIEW to help engineers configure these beasts, but who uses GPIB today?.
There are a few left-over things still to install, but it seems to be working better ...
(3,697 Views)
