Has anyone managed to install LabVIEW 2020?
I got the download and it upgraded NI Package manager but NI Package manager can't find LabVIEW 2020
Tried several times with the same results... I guess we have to wait for the hard copy to arrive?
=== Engineer Ambiguously ===
(4,742 Views)
I have installed LabView 2020 x64 using the offline installer.
via the download link
https://www.ni.com/de/support/downloads/software-products/download.labview.html
if you do the 32 Bit Version, be careful not to download the Chinese language version (default), as I did once upon a time...
(4,728 Views)
That's the same file I downloaded and that is NOT the offline installer (file size 5 MEGA-bytes)
It just upgrades the Ni Package manager and tells it to download and install LabVIEW 2020
(4,703 Views)
I found the off line installers.
The link is in very small print at the bottom of the download page.
(4,695 Views)
I tried to link to the .iso file, but it is the same link as the landing page.
sorry.
I downloaded and installed
"ni-labview-2020_20.0.0.49152-0+f0_offline.iso" ~ 42,3 GB
english only
the 32 Bit Version is smaller in size 33,5 GB
it took me several hours to download from the NI Server ....
therefore I was very amused to see, I had downloaded and install the Chinese Version -
which results in some very nasty encoding errors on my European PC
(4,663 Views)
So far, after (finally) being able to load/install LabVIEW 2019 (took me only about 4-5 months, lots of struggles) reasonably successfully, I tackled LabVIEW 2020.  I managed to install LabVIEW 2020 Community Edition (32-bit), but on my Work Machine, I just tried loading LabVIEW 2020 (32-bit) "Regular Edition".  No problem loading just LabVIEW (no modules, no drivers).  Started loading anything else (one Module, the standard Drivers, only one-at-a-time), get the stupid "Please check your internet" or other misleading/inappropriate Error messages.
And I thought I had this knocked!  Pass the Humble Pie ...
Bob Schor
(4,580 Views)
Partial success.  Did an "Uninstall NI Software and NIPM" pass, downloaded the 35 Gb .iso for LabVIEW 2020 32-bit, and gave it a shot.  Worked fine (so far) -- I have LabVIEW, DAQmx, VISA, PXI Platform Services, LabVIEW Real-Time Module, and FPGA.
One change I made to my usual "order" of installation -- as always, I installed (only) LabVIEW first, but this time, as it always "by default" turns on DAQmx, VISA, NI 488.2 (which I always manually turn off), and PXI, I let it install DAQmx, VISA, and PXI in the first pass.  Incidentally, I know NI got started making GPIB hardware many (>30?) years ago, and developed LabVIEW to help engineers configure these beasts, but who uses GPIB today?.
There are a few left-over things still to install, but it seems to be working better ...
Bob Schor
(4,551 Views)
