Have mutli ver of LV -7.1 to LV10sp1 on XP PC. DAQmx - nilvaiu.dll missing when try to open CODE from WIN7 32 bit LV10?
What Driver do I need?  VERSION Please -- DAQmx works fine in LV8.6.
(2,487 Views)
Accepted by BRIANA123
Hi Briana,
I believe I understand what you're asking, but which current DAQmx driver are you using with LV 2010?  Only the 9.1.5 and above drivers are compatible with LV 2010, while many of the older drivers will still work for you in LV 8.6.  Below, I've linked a compatibility chart for DAQmx drivers and Labview versions.
http://digital.ni.com/public.nsf/allkb/F4E76EC05118F72D8625773000672298
Does this answer your question?
Austin S.
Academic Field Engineer
(2,472 Views)
Thanks, Sorry, thought this was the solution -- Just much time to download NIDAQmx Ver 9.22 == 1.1 GB and install.  Was hoping for a easier solution.  The Version Table is very helpful Thanks -- Brian Canpbell A123Systems.
(2,460 Views)
