 xenopol
			xenopol
			05-04-2012 05:28 AM
Hy,
I want to implement in LabVIEW a logic analyzer/ digitizer using NI PXI as hardware. Have somebody try to do this or have an example? I will appreciate any opinion or support.
Thanks !
05-07-2012 03:53 PM
xenopol,
Do you currently have PXI hardware that you're trying to implement your logic analyzer/digitizer appliction with or are you looking for PXI hardware suggestions?
There is a helpful shipping example called "Logic Analyzer.vi" that comes packaged with the NI-HSDIO driver. You can locate this in Example Finder (Help > Find Examples).
05-07-2012 04:00 PM
I have the PXI hardware and I try to implement a logic analyzer... I also have LabVIEW2010 software...I search for the example that you suggest me but I don't find it in LabVIEW2010...I would appreciate if you post the example here.
Thanks !
05-07-2012 04:06 PM
xenopol,
Can you provide me with the model number(s) of the PXI modules that you're working with? There is a wide variety of modules available and I'd like to make sure that the one you're using is appropriate for this application. Thanks!
05-08-2012 06:11 AM
I work with NI PXI-1042...and the module PXI that I use to acquire digital data is NI PXI-7811R Reconfigurable I/O.
I want to read digital data from Serial and I2C transmission...
 Ben
			Ben
			05-08-2012 07:59 AM
Terminolgy may be getting in your way.
A logic analyzer will generally monitor multiple digtial lines at the same time ... like a 32 channel oscilloscope.
A Protocol Analyzer on the other hand will monitor a data line and interpret the data as bits sent one after the other.
Ben
05-08-2012 08:12 AM
I understand...I wanna implement a logic analyzer to monitor multiple lines...and I wanna test it to some circuit which comunicate Serial and I2C..
05-08-2012 03:54 PM
There are examples for I2C on our website. As far as serial, that depends on what type of serial you are talking about. I would still look on our IP network to see if the examples there serve your purpose. The website is ni.com/ipnet
Let us know if this is helpful.
Ryan
