Having placed more than one top-level VI in builder, is there a way to programmatically call the second application?
Builder allows for more than one Top-Level VI. The resulting Executable launches both applications at once. If I terminate one application, is there anyway to launch it again programmatically?
(2,730 Views)
You could monitor the names of all the VI's in memory. If the one you want running is not in the list, you can launch it dynamically.
Ben
(2,730 Views)
The resulting executable path and name is not known. I guess that when you build multiple top-level VI's it embeds the least significant executables within the first executable in the builder top-level vi list.
At least in the Solaris environment it does.
(2,730 Views)
If you strip the path twice you should get the path to the folder holding the VI's.
Ben
(2,730 Views)
You don't need the Top Level VI path. Just open a reference to the VI using its name in a path constant and open its front panel using the VI server.
LabVIEW, C'est LabVIEW
(2,730 Views)
