Having problem writing to a word bookmark
I'm having a weird problem. I'm trying to write an underlined    X    in a bookmark in word. I have 4 spaces before and after the X. at one location the program writes what I want exactly but at another location is ignores the last 4 spaces. If I write letters instead of spaces, it would write it. The code is attached along with the result. I need your help so please take a look.
Mel
(3,037 Views)
Accepted by MS2010
You will find the answer here. I don't think there is a way to do this programmatically. You can avoid the issue if you use tab instead of spaces.
Ben64
(2,992 Views)
Accepted by MS2010
It can be set programmatically, here's how to do it:
Ben64
(2,948 Views)
That worked perfectly. Thank you so much
Ben64
(2,931 Views)
Ben64
This works as well. Thanks again
(2,919 Views)
