Having problems changing sample rate from 1 HZ to 10 Hz myRIO - PmodGPS
Here is the code pertaining only to the GPS.
I'm getting the same error message with the GPS only as I am with the whole program. (see earlier attachements for the other code).
Message 11 of 21
(1,859 Views)
After messing with the program for a little while, I see the error is coming from my VISA reader just inside of my loop.
I did some searching online and found that my serial port and device may not be configured the same.
I opened Measurement and Automation explorer to check out what is going on. It appears that my port is stlill configured at 9600 but now the program is at 38400 (is that right?)
I opened the VISA test panel and I'm getting the following error
Message 12 of 21
(1,853 Views)
I can't look at the program - posting from my phone.
The settings in MAX are irrelevant. The program is not supposed to change them. The error happens because you can't open the serial port from two different programs. Your LabVIEW program has to close first.
Message 13 of 21
(1,841 Views)
What about not being able to access or read the ASRL10::instr "LPT1" ?
Both of my computers have this issue. My desk top has COM1 and 2. I can change the Baud rate on those. But I cannot get into the ASRL10::Instr "LPT1" in either computer
Message 14 of 21
(1,838 Views)
That is because it is on a real-time target like your myRIO
Message 15 of 21
(1,826 Views)
So, what do I need to change or add to get this code to work, in order to change the sampling rate?
Message 16 of 21
(1,821 Views)
LPT1 is a printer port. Don't attempt to use something that physically doesn't exist.
Message 17 of 21
(1,813 Views)
Ok, so I will ignore all of the measurement stuff, but then I'm back to where I started. How do I change the frequency?
Message 18 of 21
(1,801 Views)
I found a thread with someone having a similiar issue. Here is what he did.
My solution..
My program use wait on event triggered by the termination character and when the error occurs I just remove the error, flush the buffer, (wait for the next termination character) and read again. Seems to work like a charm
Is this a valid solution? Also, I don't understand what he is saying. How do you "just remove the error"?
(Here is the link http://forums.ni.com/t5/LabVIEW/Error-1073807253/td-p/306687/highlight/true/page/2
Message 19 of 21
(1,789 Views)
My solution..
I'm not sure how this is relevant to the changing the sample rate. Are you getting Error -1073807253 on the VISA Read call? I'd take a look at this article if you are:
http://digital.ni.com/public.nsf/allkb/F3E0621CB71AA16786256F970000FC57?OpenDocument
Daniel C.
Message 20 of 21
(1,749 Views)
