Having problems creating a folder and excel file Programmatically
@santhoshbalaji wrote:
Sorry Altenbach,
I can't handle stupidity so i'm out of this conversation
Good luck keep arguing
sorry santhoshbalaji,
I think Altenbach is making a good point
You should replace the word "stupidity" with "yourself "
Please respect others
Message 11 of 19
(4,999 Views)
Sorry Altenbach,
Altenbach is making a VERY good point.  The confusion between a true Excel formatted file and a simple delimited spreadsheet file is a common issue around here.  It's important to know the difference.
Message 12 of 19
(4,976 Views)
In all the excitement, I'm not sure anyone addressed the question that SoIPS raised, namely how to deal with nested folders and files.
Here is a little demo that illustrates how file and folder nesting work.  It starts with a root path, C:\, then appends "1.txt", "2.txt", etc., saving the growing path in Path Array.
The important point is that the final "filename", say "4.txt", is treated as a file name, while the preceding part of the path, say "C:\1.txt\2.txt\3.txt" is (automatically) treated as the Folder name.  Whatever you wire into Build Path as "Folder" (whether it is a string or a folder) will be considered a folder path, and whatever (string) you wire into File becomes the Filename, with LabVIEW automatically adding the backslash separator.
Think about how this works, then rewrite your own code to "do what you want it to do, not what you told it to do".
Message 13 of 19
(4,962 Views)
Accepted by topic author SolPS
Thanks everyone for all your responses. Matter of fact, I fgured out what I was doing wrong yesterday.  Wiring the ouput of the build path VI will create a file as opposed to wiring to the output of the create folder VI.  This VI that I attached is actually a subvi of my report generation VI which creates an excel file test report. The excel file is always created before this subvi is called.  Thanks again everyone for your input.
Message 14 of 19
(4,947 Views)
I have the same issue you had 2 years ago . Could please attach what you fixed ?
I am generating a report in labview that will be in excel and i want all my test report to be saved in the same folder .
Message 15 of 19
(4,327 Views)
As one of the contributors to the previous discussion, I need to ask that you attach your VI (don't even think about attaching a picture of your Block Diagram) and explain what you are trying to do.  For example, when you say "Excel", do you mean what LabVIEW calls a Delimited Spreadsheet File, or do you mean a file written by Microsoft Excel, having the extension .xls or .xlsx?  [Don't answer the question, rather attach your VI so we can see for ourselves what you are trying to do].
Message 16 of 19
(4,324 Views)
Thanks Bob_Schor for the quick reply .
I am trying to create a test report and i want all those report to be saved in a specific folder  automatically every time the programs runs.
Message 17 of 19
(4,320 Views)
Two suggestions:
  • Connect the .xlsx extension to the Concatenate Strings function.
  • In the Forum's Search bar, type the word "Revised " (leave out the quotes, but put in the trailing space) and see if anything looks interesting.  You should see a reasonably-complete-and-documented Example posted about 4(?) years earlier.
Message 18 of 19
(4,311 Views)
Thanks Bob
Message 19 of 19
(4,306 Views)
