Help 9472 D/O
Hi all,
I am currently working with a cRIO that has three modules. 9213, 9208, and a 9472. My current issue is with the 9213 I have 8 thermocouples. Each having there own set point for alarm. If the setpoint is reached than it enters alarm mode tripping the D/O on the 9472. Everything has been working great with my 9472 showing that it is sending a digital output when the TC's go above the set point. My issue being is that each TC goes to a different digital output. Example TC 03 on 9213 goes to D/O 03 on 9472. Is there any way to make it so that all TC's will go to the same Digital output on the 9472? Thanks.
Message 1 of 1
(1,079 Views)
