Simulating PXI 5840
I am attempting to simulate the PXI 5840 VST in LabVIEW to avoid having to take turns to test code on the physical PXI chassis. I installed NI RFSA and NI RFSG, but I do not see an option for the 5840. Is it possible to simulate this card? If not, is there a simulation option that will work similarly that could possibly be used as a substitute?
Message 1 of 1
(1,168 Views)
