Help Creating component level IP for custom adapter
Hi, I am trying to load my custom IO Module into labview/the FlexRIO FPGA. When I click on the properties of the IO Module, it pops up, but nothing appears under the component level IP.
The error I am getting are that The selected Component Level IP XML loaded with the following error(s): No IO Module CLIPs Found.
I put all the needed files in the directory and put them in the right path in the xml document. Does anyone know why my custom CLIP isn't popping up?
Thanks!
(2,514 Views)
HI bchang32,
I would go through each step in the link below and make sure you are meeting the requirements for CLIP and following the correct steps in order.
CLIP Tutorial: Adding Component-Level IP to an FPGA Project (FPGA Module)
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/clip-tutorial-adding-component-level-i...
Jiwhan S.
Technical Support Engineer
(2,428 Views)
