[Help] How to Change the number of samples X axis?
Please if any body can help me with this.
When FFT sampling frequency is 1000 [Hz]
the x axis for first graph will have 200, the second will have 500 and the third will have 500 as well. Here is the question How could I decrease the samples for the first waveform from 200 to 1 ( 0.1 0.2 0.3 ... 1)Without changing the number of samples for other graphs.
Message 1 of 10
(2,346 Views)
Can you convert your Vi to LabVIEW 2020 ("save for previous") and attach it again?
Message 2 of 10
(2,345 Views)
To be honest I don't know how this could be done
Message 3 of 10
(2,342 Views)
Message 4 of 10
(2,329 Views)
I did but I'm still not sure if the alright or not.
Message 5 of 10
(2,327 Views)
Accepted by Amer1233
You don't want to change the number of samples, just the x-axis scale (as I already mentioned in the other message:
(Right-click the graph terminal...create...property node...x-scale...offset and multipler...multiplier)
Message 6 of 10
(2,299 Views)
Unfortunately it didn't work.
Message 7 of 10
(2,285 Views)
Actually It did work now I got it. However the x axis is from 0 to 1. My goal to get 0.1 0.2 0.3 0.4 till 1 in the x axis.
Message 8 of 10
(2,272 Views)
You need to wire from the sampling frequency control, not from the data array.
Right-click the x-axis and change the formatting to show 1 decimal digits.
Message 9 of 10
(2,253 Views)
There are great training resources links at the top of the forum. Please use them!
(Who wrote the VI, it is a mess! For example I am not sure why you think you need to run two waits in parallel. In any, the longer one wins and the shorter one is irrelevant.)
Message 10 of 10
(2,242 Views)
