Help ID this board #A8CA5B
I recieved a pc with a crashed hard drive and cannot find out what drivers to use with this board. The only information I find on this board is: National Instruments GPIB-PCII/IIA, serial #A8CA5B. Can someone help me id it and find the drivers? It is for a lab. Some testing must be done through this card. Thanks
(2,607 Views)
You said it. The board is a GPIB-PCII or IIA. The drivers should be available from the National Instruments website (http://www.ni.com). As you may have guessed, it's a GPIB card.
Rob
(2,607 Views)
As Rob said the drivers are located on NI's site. More specifically try this link: http://digital.ni.com/softlib.nsf/display?ReadForm&lookup=GPIB%20Plug-In%20Controllers&view=current&node=132060_US pick your OS from the list and you should be good to go! You can also find some more information including the data sheet for it here: http://sine.ni.com/apps/we/nioc.vp?lang=US&cid=1238 .
Good luck!
Brian
(2,607 Views)
