Labview 5.1 crashes when inserting some sub vi's
Can anyone help with this problem? When I insert certain objects, for example serial port init.vi or Write Characters To file.vi from the functions palette, labview crashes with a invalid Page Fault error. These errors are becoming more frequent so now some of my vi's that use these won't open, crashing labview. Any help would really be appreciated.
Nick
(2,800 Views)
Sounds like maybe a file is corrupt or something. You may want to try reinstalling LabVIEW. If that doesn't help you'll probably get the best help by recording exactly what the Page Fault Error window says when it pops up and reporting it directly to NI at: http://ni.com/ask .
Good luck
Brian
(2,800 Views)
