Help!!! Issue on EXCEL report generation
Bao and GerdW,
Thanks for your great help, I fixed the issue this morning as GerdW mentioned yesterday that the error is about the file missing. so I fixed the code and also put the template.xlsx file into the application folder, then issue disappears.
originally, I thought that Labview will read the template file and also intergrate the file content/format into the exe application file automaticlly when I build the exe file, so I thought I do not need to move the template file into exe application folder, actually, that needs the template file.
so this is the reason, I made this stupid practice!😂
anyway, I fixed the code with adding a default file path to exe file folder, and also always copy the template file into the exe file folder, then everything works well.
thank you all for your great help!
Message 11 of 11
(584 Views)
