Help! Labview IP change!
Hello everybody!
Who can help me with the changing of IP adress for the attached project?
Project
I need two different aplications with the follow two IP adress:
192.168.1.101
192.168.1.126
Now, project have IP 192.3.101
Thank you!
Message 1 of 18
(6,207 Views)
Your project is not "attached", you've put a hyperlink to a mediafire download, containing who-knows-what.
Also, what do you mean "project has an IP address"? A LabVIEW project itself (.lvproj) does not have any IP address.
Message 2 of 18
(6,192 Views)
Sorry, but I can`t attached rar archive with my project.
It`s enought if I attached dll file?
Thank you!
Message 3 of 18
(6,189 Views)
Thank you!
Message 4 of 18
(6,188 Views)
I`m new and I dont know very well labview. I have project and I need to cheange IP adress for PLC to send data on labview.
Message 5 of 18
(6,177 Views)
Hi ml,
the forum accepts all kind of LabVIEW files and additionally text, office files and, last but not least, ZIP files...
Please attach your files directly in this thread!
Message 6 of 18
(6,157 Views)
If this dll was built in LabVIEW and the IP address is compiled in as a constant, you need the source code. Do you have it?
Message 7 of 18
(6,140 Views)
I dont have source code for this. Only labview project and this file from builded project.
Message 8 of 18
(6,133 Views)
The LabVIEW project typically contains the source code locations (VIs) and build instructions. We cannot tell what you really have unless you show us.
Message 9 of 18
(6,122 Views)
