Help! Labview IP change!
All files from project
Message 11 of 18
(2,824 Views)
Please put all in a zip file to create one single attachment so we can unzip into a separate folder. The possibilities of conflicts with similarly named files already in my download folder is just too big.
Message 12 of 18
(2,818 Views)
Hi ml,
which part of "the forum accepts ZIP files" didn't you understand?
@Christian: even worse the lvproj references the current folder as "autopopulate"…
You need to edit your MainControl.vi, the "init" case of the PLC communication state machine is important to your question!
Message 13 of 18
(2,816 Views)
Message 14 of 18
(2,805 Views)
Message 15 of 18
(2,798 Views)
Im not exactly sure, but it looks like you just need to change the string constant in the 'init' case of PLC to LabVIEW Communication loop in MainScreen.vi. Its hard coded to 192.168.3.101,1,0 right now. I would put this in a config file so you can easily edit it.
Message 16 of 18
(2,774 Views)
Can you help me with a config file for IP adress? Because I dont know how i can make it.
Thanks!
Message 17 of 18
(2,770 Views)
Help>Find Examples>Fundamentals>File Input and Output>Configuration.
That should give you a good starting point. If you get stuck, I would start a new topic specific to that question.
Message 18 of 18
(2,761 Views)
