Help: Programming a power supply using labview
Recently I have been assigned the task at work of programming our TDK Lambda power supply with Labview. IE be able to adjust the voltage from 16V to 18V and adjust it back and forth by 1 V every minute for 1 hour. Any clue where to start, because I am a little lost?
Message 1 of 8
(8,917 Views)
http://www.us.tdk-lambda.com/hp/product_html/drivers.htm
Always check the NI IDN (Instrument Driver Network) and the website of the product before writing your own drivers.  9 times out of 10 they're already written for you. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 8
(8,907 Views)
Will this work with a ZUP (TDK Lambda) version power supply
Message 3 of 8
(8,901 Views)
The drivers listed in that link are on the TDK-Lambda web site.  I seriously doubt they would mix up their command structure.  From what I've seen, TDK follows the same SCPI protocol that Agilent does.
Message 4 of 8
(8,870 Views)
Accepted by topic author breedicj
a little code to get you started... Smiley Wink
ofcourse, this is stepping the voltage only and not ramping it....
Message 5 of 8
(8,843 Views)
Thank you so much man. I'll still need to make the program to commincate with the power supply, but at least that's one big hurdle out of my way 🙂
Message 6 of 8
(8,836 Views)
Message 7 of 8
(8,796 Views)
presumably your talking over gpib, if this is the case visa writes to the specific gpib device work well.
e.g.
wire gpib::0::instr to the device input and to the write buffer *IDN? for example. You will need the manual though for the specific commands but they are probaly standard as said above
hope it gets you started
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 8 of 8
(8,775 Views)
