Help Start LabView Code for Hydraulic System
I was wondering if any can help me out with this, what I would like to have happen is everytime you press the Run button the code inside the case structure runs then when the Current Load Cell Reading is less than or equal to zero it goes back outside the case structure to be run again, but it won't run again b/c my max value isn't being reset, does anyone know of a quick way to do this...thanks...I have attached a picture of my setup and the vi
Message 21 of 21
(691 Views)
