Help building drivers for custom-built hardware over EPP (Enhanced Parallel Port) on NT
I need to build LabView drivers to run on NT for a piece of in-house custom
hardware, which has an EPP interface. I've looked at using the serial port
access to LPTn approach, however this doesn't do the job - presumably this
sends and receives data bytes but not address bytes.
I was thinking of using a driver providing user-land access to the parallel
port registers (for example, the driver HP distribute for free at
http://www.tm.agilent.com/tmo/pia/HPVEE/PIANews/software/English/HPVEE_Win32
_NTPPIO.html) and layering LabView code on top of that. Are there any other
approaches I should consider, for example is VISA capable of supporting EPP,
which requires "inport/o
utport" access to the address and data registers on
the parallel port?
TIA Kev.
Kevin F. Quinn
Email: kevq@banana.demon.co.uk
Web: www.banana.demon.co.uk
(2,894 Views)
We also have a product that uses the EPP port. I wrote a CVI driver that
controls the EPP port and this does work under windows NT. I could send you
the DLL and source code and LabVIEW VI's if this will help you.
John Harmon
Personal Email: harmonj@bright.net
Work Email: harmon-j@gouldis.com
Home Land Line: 330-848-0460
Work Land Line 216-328-7406
Fax: 216-328-7408 or 216-328-7417
"Kevin F. Quinn" wrote in message
news:384f7ff8@news.compd.com...
custom
port
> sends and receiv
parallel
other
EPP,
> which requires "inport/outport" access to the address and data registers
on
> the parallel port?
> TIA Kev.
> Kevin F. Quinn
(2,894 Views)
Hi John -
Would you send me a copy of your EPP app? I'm working on a simular problem
and am having trouble getting the parallel port to reset at the bigining
of each test.
Thaks in advance!
"John Harmon" wrote:
>We also have a product that uses the EPP port. I wrote a CVI driver that>controls
the EPP port and this does work under windows NT. I could send you>the DLL
and source code and LabVIEW VI's if this will help you.>>-->>>====================================>From:>John
Harmon>>Personal Email: harmonj@bright.net>Work Email: harmon-j@gouldis.com>Home
Land Line: 330-848-0460>Work Land Line 216-328-7406>Fax: 216-328-7408 or
216-328-7417>"Kevin F. Quinn" wrote in message>news:384f7ff8@news.compd.com...>>
I need
to build LabView drivers to run on NT for a piece of in-house>custom>>
hardware, which has an EPP interface. I've looked at using the serial>port>>
access to LPTn approach, however this doesn't do the job - presumably this>>
sends and receives data bytes but not address bytes.>>>> I was thinking of
using a driver providing user-land access to the>parallel>> port registers
(for example, the driver HP distribute for free at>>>http://www.tm.agilent.com/tmo/pia/HPVEE/PIANews/software/English/HPVEE_Win32>>
_NTPPIO.html) and layering LabView code on top of that. Are there any>other>>
approaches I should consider, for example is VISA capable of supporting>EPP,>>
which requires "inport/outport" access to the address and data registers>on>>
the parallel port?>>>> TIA Kev.>> -->> Kevin F. Quinn>> Email: kevq@banana.demon.co.uk>>
Web: www.banana.demon.co.uk>>>>>>>>
(2,894 Views)
