Help convert from 7 to labview 6.1
Could anyone help me to convert the code to labview 6.1
Thankyou very much
(2,879 Views)
If you have Labview 7.0 installed on ur machine , then open the file in 7.0 and go to File - Save with Options and select save for Previous version 6.1. that shoud do it
(2,865 Views)
Definitely, I don't have labview7.1. I only have labview6.1 that why i need the file to be converted to 6.1.
(2,856 Views)
You can try creating a 6.1 driver yourself. All the IVI drivers are simple wappers around a Call Library Node Function into the DLL created in LabWindows/CVI. The LabVIEW driver is created from the Tools>Instrumentation>Import CVI Instrument Driver selection. Download the CVI driver and install it. The converter will require some files installed in the \VXIpnp\WinNT (.fp) and \VXIpnpWinNT\bin (.dll) folders.
(2,837 Views)
