Help converting hexadecimal to ASCII
Hi!
I have somewhat successfully converted hexadecimal to ASCII however the final display would add unnecessary spaces in front of the word.
Is there another way to convert hexadecimal to ASCII?
Message 1 of 14
(7,255 Views)
Can you "save for previous" (and select LabVIEW 2020 or lower) and attach the down-converted version. I cannot see your VI.
The question itself is not clear at all, because ASCII is just a convention to assign characters and control codes to bit patterns, i.e. how they are displayed or what they mean, e.g. linefeed. There is no "conversion" per se. Similarly "hexadecimal" is also very ambiguous. Is it a binary string? A formatted string containing ASCII characters 0..F exclusively? Something else?
Message 2 of 14
(7,217 Views)
Accepted by Gared898
You need to be splitting up into every 2 characters, turning those into a byte, building an array of those values, and then you can convert that to a string. Instead you're generating an I64 but you're only populating some of the bytes of it with the upper 3 bytes still being 0s. When trying to convert numbers to strings you do not want to be touching type cast.
~ Helping pave the path to long-term living and thriving in space. ~
Message 3 of 14
(7,215 Views)
The problem is your 64 bit integer has a bunch of leading zeros that get turned into spaces.
You need to convert the hex to ASCII one letter at a time and use an 8 bit integer for the Hex string to Number conversion
It's a little Rube Goldberg but this is what I came up with.
EDIT: A little less Rube Goldberg
=== Engineer Ambiguously ===
Message 4 of 14
(7,202 Views)
Message 5 of 14
(7,181 Views)
sometimes it helps to search the forum first:
Message 6 of 14
(7,143 Views)
If the input string is guaranteed to be clean (even number of characters, only 0..F), I might use a map constant, especially if the string is very long (error handling can be added if a key is not found):
Message 7 of 14
(7,133 Views)
Fun fact: Byte Array to String is a no-op unless the resulting string or source array gets modified further. Type Cast goes through a serialization/deserialization and therefore a memory copy operation. For small sizes and infrequent operations... who cares, but type cast can add unnecessary overhead for repeated/larger operations.
Message 8 of 14
(7,111 Views)
You would think that if we are dealing with an U8 array, the compiler would generate identical code... 😄
Message 9 of 14
(7,102 Views)
In theory but in practice most nodes are more or less direct calls to a precompiled C function in the LabVIEW kernel save from some optimizations done by the compiler for unused parameters or alternative code paths. So if you place a Typecast on the diagram, the according Typecast C function is invoked which is prepared to deal with arbitrary (flat) data. The String to Byte Array function and its inverse sibling are a bit special as there is no C function needed behind it. It simply changes the diagram datatype  and has flags telling the compiler that it does not modify the data in any way itself. For the rest it is a real NOP especially at runtime.
Rolf Kalbermatter  My Blog
Message 10 of 14
(7,025 Views)
