Help converting old libraries from LV5.1.1 to LV8.2.1
Thanks in addvance for your help.
(2,544 Views)
Accepted by JoelQuinteroIQ
Post your code in the attached link
https://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
(2,532 Views)
Thanks, for the hurry I confused the forum.
(2,519 Views)
Conversion done here: https://forums.ni.com/t5/Version-Conversion/Help-converting-old-libraries-from-LV5-1-1-to-LV8-2-1/m-...
(2,502 Views)
