Help converting old libraries from LV5.1.1 to LV8.2.1
Thanks in addvance for your help.
(2,529 Views)
Accepted by topic author JoelQuinteroIQ
Post your code in the attached link
https://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,517 Views)
Thanks, for the hurry I confused the forum.
(2,504 Views)
Conversion done here: https://forums.ni.com/t5/Version-Conversion/Help-converting-old-libraries-from-LV5-1-1-to-LV8-2-1/m-...
(2,487 Views)
