Help>Help for this VI
hi ,
i want to  open  my Help file (.chm) in LabVIEW using the item Help for this VI under Help menu .
this my program but it dosen't work .
Best Regard.
(2,153 Views)
Hi Emna20,
For this you need to your VI Should be in running state, During when if you click Help for this VI then you will be able to see the contents in the help file.
(2,115 Views)
