Help issues with arrays
The purpose of the project is for the user to enter some ingredients as input and the project given 10 pre-set recipes will go looking for which recipe contains the ingredients entered by the user
i've tried so many times can someone help me pls?
Message 1 of 22
(4,041 Views)
Maybe you can describe in words what you have tried so far ?  or even show some code ?
Message 2 of 22
(4,031 Views)
this is what i have done : (link deleted)
Message 3 of 22
(4,007 Views)
I would like when searching for one of the words in the constant array to find the array row to which that word belongs. but as you can see, there may be some errors.
Message 4 of 22
(4,004 Views)
What is the outer loop doing ?
So you want to select each word in the constant array or the ingredients array ?  and search for it in which array ?
You need to give your arrays and constants meaningful names . . .  it helps you keep focused on what you are trying to do.
Message 5 of 22
(3,995 Views)
Please do not host attachments on ad and popup riddled external sites. You can attach your code to the post right here!
It is not acceptable to expose forum users to deceptive redirects and a jungle of clicks just to get your attachment.
Message 6 of 22
(3,991 Views)
sorry didnt know that
Message 7 of 22
(3,973 Views)
Maybe you can make use of this.
Message 8 of 22
(3,950 Views)
Do you want only the recipies that contains all ingredients, or all that contains any of them?
Either way your comparison is wrong, put probes and run in highlight mode so see what's actually being produced.
Right now you're comparing with the 1st row of your constant every time.
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 22
(3,935 Views)
Accepted by GamerBlock27
See if this can give you some ideas..... (note: Inputs are limited to single line for obvious reasons. You might want to do things case insensitive and ignore whitespace, etc.)
Message 10 of 22
(3,911 Views)
