Help needed moving Labview 2020 SP1 License to another machine
I use LabView 2020 SP1 at work and the time has come to upgrade the PC. This PC is not connected to the Internet. The license is currently active and the License server says that the License does not expire. What are the steps needed to do this... I need to advise our customer what steps to take, thanks.
(537 Views)
Get the Serial Number from NI License Manager, then Activate NI Software Without Internet Connection for the new PC.
If the old PC was activated using the activation code, then you have to figure out the Serial Number used for the activation.
https://tmesystems.net/
(489 Views)
