Interfacing with PXI-8531 using J1939 in LabView
We have a PXIe-8881 embedded controller with NI Linux RT and a PXI-8531 CANOpen Interface Module. We want to use J1939 protocol to interface with our CAN device.
I was able to read raw CANopen messages with the CANopen Read CAN Frame.vi example using NI-Ind Com for CANopen driver. Are there any drivers I can use for J1939? Is there a way to filer COB-IDs so I'm only reading J1939 based messages? What would be the best method to go about this on LabView?
(771 Views)
Hi purple,
you better use a plain CAN card instead of this specific CANopen card…
(750 Views)
Hi GerdW,
Thank you for your response.
We are using the PXI-8531 since our CANopen device can utilize CANopen and J1939. We would prefer using J1939 if possible. Would interfacing with the PXI-8531 using J1939 on LabView not be possible? Both are higher layer protocols above CAN physical layer...
(724 Views)
Hi purple,
CANopen uses 11bit ArbIDs, J1939 uses 29bit ArbIDs...
I never used this CANopen card, so you better read its manual to learn as about its capabilities.
(717 Views)
@purple15 wrote:
Hi GerdW,
Theoretically possible but the NI-IndComms for CANopen driver does not support J1939 and you would need to develop the entire J1939 application layer yourself.
The easiest way is to use NI-XNET hardware like PXI-8513 which has native support of J1939.
https://tmesystems.net/
(684 Views)
