Help on NI Speedy-33 (2 questions)
Yup, DSP module does have the FFT Spectral measurement but not the bundle function... 😞
By the way, what is the array of numbers (what does it mean) added to the magnitude (after FFT) and wat's is the purpose for the bundle and unbundle?
Thanks-in advance!
Message 21 of 26
(1,058 Views)
OK so the DSP toolkit do have a FFT function. So far so good. Does this function have a standard Labview equivalent ? Your problem is how to scale the output. Can you post any documentation?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 22 of 26
(1,055 Views)
Hmm.. I'm getting very confused.  What documentation r u refering to? The FFT express VI in DSP module is exactly the same that you have shown.
Firstly, a frequency spectrum of the signal is performed (to simpify things, the FFT spectral measurement vi is used)
Secondly, due to the complexity of bilinear transform, A-weighted filter in frequency domain is applied according to the formula posted.
Hence, how do I apply it? From ur example VI, I cant  see the amplitude being attenuated by varying the input frequency...
Thanks!
Message 23 of 26
(1,045 Views)
skip the bundeling operation. just add the array constant directly to DSP spectrum output.
Message 24 of 26
(1,042 Views)
How did you work out the array of constant with a size of 11025? From the formula?
By the way, is there a convolution in the formula?
Message 25 of 26
(1,033 Views)
hey
BK could you please help me in this field, umm my task is to design spl meter using speedy 33 kit, it seems as u have done some work on it,, please let me know if u can or anyother person can help me out of it.
Thanking all of u in advance 🙂
Message 26 of 26
(910 Views)
