04-04-2009 01:12 PM
Yup, DSP module does have the FFT Spectral measurement but not the bundle function... 😞
By the way, what is the array of numbers (what does it mean) added to the magnitude (after FFT) and wat's is the purpose for the bundle and unbundle?
Thanks-in advance!
04-04-2009 01:27 PM
04-04-2009 01:59 PM
Hmm.. I'm getting very confused. What documentation r u refering to? The FFT express VI in DSP module is exactly the same that you have shown.
Firstly, a frequency spectrum of the signal is performed (to simpify things, the FFT spectral measurement vi is used)
Secondly, due to the complexity of bilinear transform, A-weighted filter in frequency domain is applied according to the formula posted.
Hence, how do I apply it? From ur example VI, I cant see the amplitude being attenuated by varying the input frequency...
Thanks!
04-04-2009 02:04 PM
04-04-2009 02:28 PM
How did you work out the array of constant with a size of 11025? From the formula?
By the way, is there a convolution in the formula?
06-30-2010 07:52 PM
hey
BK could you please help me in this field, umm my task is to design spl meter using speedy 33 kit, it seems as u have done some work on it,, please let me know if u can or anyother person can help me out of it.
Thanking all of u in advance 🙂
