Help parsing UDP Packet
Accepted by joe5213
Almost there! But there's no need for all the indicators and local variables. Make a copy of the MY_UDP indicator, change to a control, and wire it to the "type" input of Type Cast. Or, slightly better, make a constant instead from the MY_UDP indicator and use that for the type. It will be a large constant, but you can move it outside the loop if you don't want the loop to blow up.
Also, eventually you should make that cluster into a Type Definition (see the help) so that if it changes, you only need to update the type definition and it all the instances of it will be updated to match.
Message 11 of 15
(2,864 Views)
Thank you very, very much for all your help.
Message 12 of 15
(2,853 Views)
hi  nathand,
I have used UDP write and read in the LabVIEW palletes for my testing. It gives the data only, can i get the complete UDP Frame (Raw Data).
I have gone through this link https://forums.ni.com/t5/Example-Code/Ethernet-Packet-Sniffer-Utility-Using-WinPcap-Functions/ta-p/3... but in this example is the receiving the data , i also have to send in the same way .
Do we have any other way using the winpcap in LabVIEW.
inputs :
 1. Data rate is 100 kbps.
 will this be helpfull for me please help me.
Thanks in Advance
Ikram
Message 13 of 15
(2,685 Views)
The built-in UDP functions provide only the data, which is by far the most common use case. I do not know of a library that allows you to manipulate raw packets, you'll have to do some searching to see what your options are. Why do you need raw access to the packets?
Message 14 of 15
(2,656 Views)
Also, you should start a new thread, since you're responding to a post that was marked as solved over a year ago.
Message 15 of 15
(2,652 Views)
