Help passing array to dll error 998 ERROR_NOACCESS ?
I'm trying to pass an array to a dll in a sub VI and it wont work, our dll func keeps returning error 998. I believe this is the Windows error ERROR_NOACCESS
Ive attached the vi.
I'm Using Array Data pointer 1D array of unsigned 8 bit bytes
The dll func returns either a 4 6 or 12 byte array depending on which board its talking too.
A previous contractor that wrote this  vi claims the 4 byte version was working but I cant get either to work.
Several customers have tried to do this and all have faled.
At this time we cant change our C dll.
I'm using LabView 7, I just got approval to buy LabView 2010, I'm not sure if that will help this issue though.
using WinXP Pro
Any suggestions would be greatly appreciated.
Is there a way to pass a fixed length array in as a pointer? Cant seem to figure thast out. Cluster?
I'll keep working on it and searching for clues here in the forum.
Cheers,
Richard
(3,305 Views)
OK still working on this one.
It looks like we report this error in our driver when someone passes a NULL pointer or a pointer to an array that is too short and we cant do a proper copy of the buffer or a write to the buffer array.  so what exectrly gets passed down from LabView??? from my reading so far it looks lik its like "unsighned char Buffer[]"  which should work fine, also we dont resize the array at any time just basically write 4, 6 or 12 (8 bit) bytes to it.  Any suggestions? writing a CIN doesnt seem like a practical solution.  Ive checked and tested all the CLFN configure possibilities.  Labview reports #0 for the array going into the CLFN or comming out?  Is Labview sending a NULL pointer to our dll???
(3,301 Views)
Accepted by Delphin25
Maria from tech Support is a Goddess!!!!!!!!!!!!!!!!!!
The key was to have an array input as I was doing, but then set it to ones "1" non zero value.  I had created a 6 wide array but left the values at the default zeros which was in effect uninitialized or NULL  buffer[0] = 0 hence buffer[] or *buffer is NULL pointer which blew chunks in our driver LOL  . whats funny is in Labview even if i set the values back to 0's its doesnt revert back to null it still thinks its a 6 element array.  Have to look into how to init this thing to 0 properly but 1's are fine to ensure for customers its not null.  thanks all for looking.
(3,293 Views)
To ReInit your array from the front panel, right click on the control then Data Operations->ReInitialize to Default or Data Operations->Empty Array.
If you're doing this from a block diagram, you should just be able to reinit by using an array constant.
(3,289 Views)
Yeh I attached the fixed version for comparison.
But your right if I set the values to 12 zeros then right click  data operastiom "make current value default" then reinitialize to defaults then it stay as a 12 element array and works.  as indicated in run mode with highlight execution on, it shows up as a #12 instead of #0
Now if I make it a constant instead of a control or indicator it works the only difference is now if you look at the block diagram the 0-11 elements are bold and 0 instead of grayed out and zero which is uninitialized that the key.  So if i leave it like that and just make a big note to users in the comments and on the sub vi fp too to leave this alone or you will cause the bug again I should be fine also leave it at index 11 so they can see its initialized to zeros.  Thanks for the reply. Interesting stuff.
(3,287 Views)
